Model.CE_FE_LoadFeConfig#
Model.CE_FE_LoadFeConfig(filename, load_option, overwrite)#
Loads or unloads an FE config file.
Parameters:
  • filename (hwString) – The full path and filename of the FE config file.
  • load_option (int) –
    0 - To unload.
    1 - To load.
  • overwrite (int) –
    Valid only when load_option=1.
    0 - Skip FE types with names or IDs conflicting with existing ones.
    1 - Overwrite existing FE types with names or IDs conflicting with current ones.
Example#
Load the FE config file “C:/test/my_feconfig.cfg” and overwrite existing FE types with those in the file#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_FE_LoadFeConfig(filename="C:/test/my_feconfig.cfg", load_option=1, overwrite=1)
