Model.hm_mapelementstoplane#
Model.hm_mapelementstoplane(collection)#
Performs fast unfolding of a given set of connected shell elements onto a plane, while minimizing deformation for each element.
The result is returned as a list with a number of entries equal to the number of nodes in the set of selected elements.
Each entry in the list consists of the node ID and mapped node u-v coordinates onto the plane.
Parameters:
collection (Collection) – The collection containing the entities of the shell elements to map.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • Result (HmQueryResultList)-Result list object containing HmQueryResult objects with the following output data:
      • node (Entity) - Node corresponding to a selected element onto the plane - Entity Type: Node
      • uCoordinate (double) - Mapped node u-coordinate onto the plane
      • vCoordinate (double) - Mapped node v-coordinate onto the plane
Example#
Get the mapping for all elements to a plane#
import hm
import hm.entities as ent
model = hm.Model()
elems = hm.Collection(model, ent.Element, populate=True)
_, resultObj = model.hm_mapelementstoplane(collection=elems)
resultlist=resultObj.Result
for result in resultlist:
    print("node", result.node)
    print("uCoordinate", result.uCoordinate)
    print("vCoordinate", result.vCoordinate)
