Model.ME_ModuleOccurrenceConvert#
- Model.ME_ModuleOccurrenceConvert(part_entity, type, reserved)#
Converts a module from part to part assembly and vice-versa, assuming it’s allowed from the current hierarchy status and entity containment rules. To check if the conversion is allowed, use hm_me_moduleoccurrenceconvert_isallowed.
- Parameters:
part_entity (Entity) – The object describing the entity.
type (hwString) –
part - Converts the module to a part. That means it will become a leaf in module hierarchy and cannot contain other parts or part assemblies, only other entity types. A module explicitly created as part assembly cannot be converted to part.
assembly - Converts the module to a part assembly. That means it will be able to hold other parts and part assemblies, as well as other entity types based on entity containment rules.
reserved (hwString) – Reserved for future use. Must be set as “”.
Example#
Convert module with ID 168 from a part assembly to a part#import hm import hm.entities as ent model = hm.Model() model.ME_ModuleOccurrenceConvert( part_entity=ent.Part(model, 168), type="part", reserved="" )
