Model.hm_getwhollycontainedcollectormark#
- Model.hm_getwhollycontainedcollectormark(collection, collector_collectionset, reverse)#
Returns the collectors that fully contain the input entities.
- Parameters:
collection (Collection) – The collection containing the input entities to query. Valid entities are elements, loads, curves, systems, vectors.
collector_collectionset (CollectionSet) –
The set of collections containing the collectors that fully contain the input entities. Respectively to the enitity type of
collectionthe entity types can be:For elements in
collection\(\rightarrow\) the entity type is component.For loads in
collection\(\rightarrow\) the entity type is load collector.For curves in
collection\(\rightarrow\) the entity type is plot.For systems in
collection\(\rightarrow\) the entity type is system collector.For vector in
collection\(\rightarrow\) the entity type is vector collector.
reverse (bool) –
0 - Find only fully contained collectors.
1 - Find not-fully contained collectors.
- Returns:
hwReturnStatus- Status object
Examples#
Find the components that fully contain elements with IDs 1 - 100#import hm import hm.entities as ent model = hm.Model() elem_collection = hm.Collection(model,ent.Element,list(range(1,101))) out_colSet = hm.CollectionSet(model) model.hm_getwhollycontainedcollectormark(collection=elem_collection,collector_collectionset=out_colSet,reverse=0) for col in out_colSet: print("Collector type:", col.eclass.__name__) print("Collectors:", [c.id for c in col])
Find the components that simply contain elements with IDs 1 - 100#import hm import hm.entities as ent model = hm.Model() elem_collection = hm.Collection(model,ent.Element,list(range(1,101))) out_colSet = hm.CollectionSet(model) model.hm_getwhollycontainedcollectormark(collection=elem_collection,collector_collectionset=out_colSet,reverse=1) for col in out_colSet: print("Collector type:", col.eclass.__name__) print("Collectors:", [c.id for c in col])
