Model.midsurface_unsuppress_conflict_edges#
- Model.midsurface_unsuppress_conflict_edges(reserved1, reserved2)#
Unsuppresses edges that separate surfaces with differing plate information. This happens when one of the surfaces has plate information and the other does not, when the two surfaces have different plate numbers, or when the two surfaces have different plate types.
- Parameters:
reserved1 (int) – Reserved for future use. Must be set to 0.
reserved2 (int) – Reserved for future use. Must be set to 0.
Example#
Unsuppress all edges of the model that separate surfaces with differ plate information#import hm import hm.entities as ent model = hm.Model() model.midsurface_unsuppress_conflict_edges(reserved1=0, reserved2=0)
