Model.modent_export#
- Model.modent_export(entity, file_name, options)#
Exports a modular entity and its contents using the currently loaded solver template.
- Parameters:
entity (Entity) – The object describing the modular entity to export. Valid entities are subsystem.
file_name (hwString) – Full path and file name of the file to export.
options (hwString) –
Optional list of quoted, comma separated option strings.
exporttype=<value>
The type of exported file (value) is:
solverdeck - An FE solver.
Example#
Export the contents of subsystem with ID 2 into an LS - DYNA deck named “ C:/export / Subsystem2_Crash5mm.k “#import hm import hm.entities as ent model = hm.Model() model.modent_export( entity=ent.Subsystem(model, 2), file_name="C:/export/Subsystem2_Crash5mm.k", options="exporttype=solverdeck", )
