Model.tableupdatecolumn#
Model.tableupdatecolumn(name, data_flag, data_type, column_label_flag, column_label, string_array, column_index)#
Updates the values in a column of a table.
Parameters:
  • name (hwString) – The name of the table to update.
  • data_flag (unsigned int) – A flag defining if the data_type and column data contained in string_array should be updated (1) or ignored (0).
  • data_type (hwString) – The data type of the column. See Model.tablecreate() for valid values. Ignored if data_flag=0.
  • column_label_flag (unsigned int) – A flag defining if the column_label should be updated (1) or ignored (0).
  • column_label (hwString) – The label of the column. Ignored if column_label_flag=0.
  • string_array (hwStringList) – The string array that contains the column data to update. The length of the list should be equal to the number of rows in the table. Ignored if data_flag=0.
  • column_index (unsigned int) – The index of the column to update. Tables are indexed starting from 1 (1 to n columns).
Example#
Update the data of column 3 of “ table1 “ which has 7 rows of integers , but ignore the label#
import hm
import hm.entities as ent
model = hm.Model()
model.tableupdatecolumn(
name="table1",
data_flag=1,
data_type="int",
column_label_flag=0,
column_label="",
string_array=["1", "2", "3", "4", "5", "6", "7"],
column_index=3,
