Model.checkpenetration#
Model.checkpenetration(collection, dim_type, penetrations, self_interference, thickness_adjust, thickness_param, threshold_depth, reserved)#
Checks a group of elements for penetrations and/or self-interference.
Parameters:
  • collection (Collection) – The collection containing the entities to check fro penetration. Valid entities are elements, components and groups.
  • dim_type (int) –
    The dimensionality of the elements to check within the collection:
    0 - Check 2D and 3D elements.
    2 - Check 2D elements only.
    3 - Check 3D elements only.
  • penetrations (int) –
    0 - Ignore penetrations
    1 - Consider penetrations
  • self_interference (int) – Flag to consider self-intersections and penetrations within component.
  • thickness_adjust (int) –
    Adjust thickness flag:
    0 - Use components’ thickness values.
    1 - Multiply component’s by thickness_param.
    2 - To directly specify all thicknesses via thickness_param.
  • thickness_param (double) – Thickness, or thickness multiplier, depending on the thickness_adjust setting.
  • threshold_depth (double) – Do not consider penetrations with depths less than this value. To find zero-depth penetrations, specify any negative value.
  • reserved (int) – Reserved for future development. Must be set to 0.
Example#
Check all groups for penetrations#
import hm
import hm.entities as ent
model = hm.Model()
groups = hm.CollectionByDisplayed(model, ent.Group)
model.checkpenetration(
    collection=groups,
    dim_type=0,
    penetrations=1,
    self_interference=0,
    thickness_adjust=0,
    thickness_param=0.0,
    threshold_depth=0.0,
    reserved=0
