Model.jointelement_sixnoded#
- Model.jointelement_sixnoded(type, n1, n2, n3, n4, n5, n6, orientation, system1, system2, property)#
Creates a six-noded joint element.
- Parameters:
type (int) – The type of the element (6 or 7 ONLY).
n1 (Entity) – The entity of the first node.
n2 (Entity) – The entity of the second node.
n3 (Entity) – The entity of the third node.
n4 (Entity) – The entity of the forth node.
n5 (Entity) – The entity of the fifth node.
n6 (Entity) – The entity of the sixth node.
orientation (int) –
Orientation option for the element. Use:
0 - None
1 - Systems
system1 (Entity) – The first orientation system entity for the elements.
system2 (Entity) – The second orientation system entity for the elements.
property (hwString) – The property to which the element points.
Example#
Create a six - noded joint element from nodes with IDs 464,457,456,455,463,462 and orientation systems with IDs 1596, 1592#import hm import hm.entities as ent model = hm.Model() model.jointelement_sixnoded( type=1, n1=ent.Node(model, 464), n2=ent.Node(model, 457), n3=ent.Node(model, 456), n4=ent.Node(model, 455), n5=ent.Node(model, 463), n6=ent.Node(model, 462), orientation=1, system1=ent.System(model, 1596), system2=ent.System(model, 1592), property="", )
