Model.surface_stitch#
- Model.surface_stitch(collection, allow_self_stitch=1, allow_stitch_different_surfs=1, stitch_only_free_edges=1, stitch_to='across_comp', allow_small_edge_collapse=0, tolerance_across=0.000000, tolerance_within=0.000000)#
Performs stitching of edges within surfaces or/and between surfaces.
- Parameters:
collection (Collection) – The collection containing the surfaces to be stitched.
allow_self_stitch (unsigned int) –
Specifies whether to consider stitching edges of the same surface. Valid values are:
0 - Do not consider self-stitching.
1 - Consider self-stitching (same surface edges).
allow_stitch_different_surfs (unsigned int) –
Specifies whether to consider stitching edges between different surfaces. Valid values are:
0 - Do not stitch edges between different surfaces.
1 - Stitch edges between different surfaces.
stitch_only_free_edges (unsigned int) –
Specifies whether to restrict to free edges for stitching. Valid values are:
0 - Consider all edges.
1 - Consider free edges only.
stitch_to (hwString) –
Specifies which edges to consider for stitching. Valid values are:
across_comp - Allow stitch between components.
within_comp_only - Do not stitch between components.
to_connected_surfs - stitch between selected surfaces and surfaces connected to selection.
within_selection - stitch only within the subset of selected surfaces.
allow_small_edge_collapse (unsigned int) –
Specifies whether to allow collapsing small edges when stitching. Valid values are:
0 - Do not collapse small edges.
1 - Collapse small edges.
tolerance_across (double) – The stitching tolerance value for edges of different surfaces. The default geometry tolerance is used if this input is not specified.
tolerance_within (double) – The stitching tolerance for edges within a single surface. The default geometry tolerance is used if not specified.
Example#
Stitch edges between all displayed surfaces using a tolerance value of 0.2#import hm import hm.entities as ent model = hm.Model() disp_surfs = hm.CollectionByDisplayed(model,ent.Surface) model.surface_stitch(disp_surfs,tolerance_across=0.2,tolerance_within=0.2)
