Model.surfaceintersectmark#
- Model.surfaceintersectmark(collection1, plane_flag, plane_normal, plane_base, collection2)#
Creates lines by intersecting surfaces with a plane or other surfaces. The line segments are organized into the current component.
- Parameters:
collection1 (Collection) – The collection containing the surface entities to intersect.
plane_flag (int) –
0 - Use
collection2to define the surfaces to use for the intersection.1 - Use the plane defined by the
plane_normalandplane_baseto use for the intersection.plane_normal (hwTriple) – The hwTriple object defining the plane normal components to use for intersection. User can also supply a Python list of three doubles. Valid when
plane_flag=1.plane_base (hwTriple) – The hwTriple object defining the base point components of the plane to use for intersection. User can also supply a Python list of three doubles. Valid when
plane_flag=1.collection2 (Collection) – The collection containing the surface entities to use for intersection. Valid when
plane_flag=0.
Examples#
Create intersection lines for the xy - plane with a base node of ( 0.0 , 10.0 , 0.0 ) with the displayed surfaces#import hm import hm.entities as ent model = hm.Model() model.surfaceintersectmark( collection1=hm.CollectionByDisplayed(model, ent.Surface), plane_flag=1, plane_normal=[0.0, 0.0, 1.0], plane_base=[0.0, 10.0, 0.0], collection2=hm.Collection(model, ent.Surface, populate=False), )
Create intersection lines for the intersection of surfaces with IDs 1 and 2 with surfaces with IDs 10 and 11#import hm import hm.entities as ent model = hm.Model() model.surfaceintersectmark( collection1=hm.Collection(model, ent.Surface[1, 2]), plane_flag=0, plane_normal=None, plane_base=None, collection2=hm.Collection(model, ent.Surface, [10, 11]), )
