Model.createspotweld#
- Model.createspotweld(independent, dependent, length_given, length, systems, movenode, remesh, configval, property)#
Creates a spotweld between two nodes on the finite element mesh for a given type of element, coordinate system, and property ID.
- Parameters:
independent (Entity) – Independent node pointer entity.
dependent (Entity) – Dependent node pointer entity.
length_given (int) – Specifies if a length has been given.
length (double) – Length of the spotweld element.
systems (int) –
Local coordinate system switch.
0 - Without coordinate system.
1 - With coordinate system.
movenode (int) – Moves dependent node.
remesh (int) – Remeshes dependent region.
configval (int) – Element type configuration value.
property (hwString) – Name of property collector Retrieves property ID.
Example#
Create a spotweld ( spring element ) between nodes with IDs 1 and 3 with the coordinate system and property collector “ name_prop “ (movenodeandremeshoptions are not used )#import hm import hm.entities as ent model = hm.Model() model.createspotweld( independent=ent.Node(model, 1), dependent=ent.Node(model, 3), length_given=0, length=0.0, systems=1, movenode=0, remesh=0, configval=21, property="name_prop", )
