Model.morphconstraintcreatesmooth#
Model.morphconstraintcreatesmooth(nlist, type, closed, name, color)#
Creates a smooth type morphconstraint for the selected nodes. During morphing, the perturbations of the nodes or dependent handles will be modified using a spline based approximation so that edge domains running along the selected entities will have smooth contours.
Parameters:
  • nlist (EntityList) – The list containing the node entities.
  • type (int) –
    0 - Apply to nodes. All handles on the node list serve as anchors for the spline curve and nodes are adjusted to the curve based on influences
    1 - Apply to dependent handles. Only the independent handles on the node list serve as anchors and the dependent handles are adjusted to the curve based on influences
  • closed (int) –
    0 - Open ended
    1 - Loop. The first node on the list will be added to the end to form a loop.
  • name (hwString) – The name of the morph constraint.
  • color (int) – The color of the constraint. Valid values are 1-64.
Example#
Create a smooth morphconstraint for nodes with IDs 1 - 5 with a closed loop#
import hm
import hm.entities as ent
model = hm.Model()
model.morphconstraintcreatesmooth(
    nlist=[
        ent.Node(model, 1),
        ent.Node(model, 2),
        ent.Node(model, 3),
        ent.Node(model, 4),
        ent.Node(model, 5),
    type=0,
    closed=1,
    name="smooth",
    color=32,
