Model.hm_isentitydatanameparameterized_byentity#
Model.hm_isentitydatanameparameterized_byentity(entity, attribute_id, row=-1, column=-1)#
Returns parameter ID if the specified data name or attribute is parameterized, otherwise returns value of 0.
Parameters:
  • entity (Entity) – The object describing the entity to query.
  • attribute_id (int) – The template attribute ID to query.
  • row (int) – Row index for a 1D or 2D array. For a 1D array, it checks the parameterization at the specified row index. For a 2D array, it will check for the entire row. This should be blank for non-array data names/attributes.
  • column (int) – Column index for a 2D array. Used together with row_index, it checks the parameterization at the specified row_index and column_index. This should be blank for non-array data names/attributes.
Returns:
Example#
Check the parameterization of attribute with ID 1 for set entity with ID 5#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_isentitydatanameparameterized_byentity(
    entity=ent.Set(model, 5),
    attribute_id=1
print("parameterID", result.parameterID)
