Model.defaultmeshelems#
- Model.defaultmeshelems(collection, elem_size, elem_type, elem_type_2, comp_mode, size_control, skew_control, edge_mesh_type, min_size, max_size, max_deviation, max_angle, previous_settings, vertex_angle)#
Meshes a selection of elements using saved or default parameters and various options.
- Parameters:
collection (Collection) – The collection containing the element entities to mesh.
elem_size (double) – The default element size used to calculate element densities along edges (when necessary).
elem_type (int) –
Flag indicating the elements generated for mapped meshing algorithms. Valid values are:
0 - trias
1 - quads
2 - mixed
3 - right trias
4 - quads only
elem_type_2 (int) –
Flag indicating the elements generated for free meshing algorithms. Valid values are:
0 - trias
1 - quads
2 - mixed
3 - right trias
4 - quads only
comp_mode (int) –
Parameter specifying how entities are organized into components:
0 - Elements are created in the current component. Boundaries between components are not maintained when remeshing.
1 - Elements are created in the same components as the source elements. Boundaries between components are maintained when remeshing.
size_control (int) –
Flag indicating whether to create uniformly sized elements. Valid values are:
0 - Do not create uniformly sized elements.
1 - Create uniformly sized elements.
skew_control (int) –
- Flag indicating whether to create optimally shaped elements when using mapping
0 - Do not create optimally shaped elements.
1 - Create optimally shaped elements.
edge_mesh_type (int) –
Determines the algorithm for edge meshing:
1 - Standard edge meshing.
2 - Chordal deviation edge meshing.
11 - Standard edge meshing with flow “align” control.
12 - Chordal deviation edge meshing with flow “align” control.
14 - Standard edge meshing with flow “align” and “size” control.
min_size (double) – Minimum edge size for chordal deviation edge meshing. Ignored, if
edge_mesh_typeis not set to 2 or 12.max_size (double) – Maximum edge size for chordal deviation edge meshing. Ignored, if
edge_mesh_typeis not set to 2 or 12.max_deviation (double) – Maximum deviation for chordal deviation edge meshing. Ignored, if
edge_mesh_typeis not set to 2 or 12.max_angle (double) – Maximum angle value (in degrees) between edges for chordal deviation edge meshing. Ignored, if
edge_mesh_typeis not set to 2 or 12.previous_settings (int) –
Flag indicating whether to break, keep or redo connectivity between neighboring surfaces. Valid values are:
0 - Keep previous settings and do not break connectivity between neighboring surfaces.
1 - Break connectivity between neighboring surfaces.
2 - Keep connectivity between neighboring surfaces.
3 - Redo connectivity between neighboring surfaces by expanding surface selection by one layer of adjacent surfaces.
vertex_angle (double) – When the vertex between two edges exceeds this value, a new node is created to form a vertex. Thus, using high values results in fewer nodes on curved edges, and therefore less-accurate edge approximation. A standard value is
vertex_angle=30.0.
Example#
Mesh all elements with a first order mixed mesh of size 4.5 , maintain the original components , with size and skew control , with flow and alignment control , keep the exist connectivity , a vertex angle of 25 , and automatically detect connected features with a feature angle of 20#import hm import hm.entities as ent model = hm.Model() hm.setoption(element_order=1) hm.setoption(feature_angle=20) model.setusefeatures(mode=3) inp_col = hm.Collection(model, ent.Element) model.defaultmeshelems( collection=inp_col, elem_size=4.5, elem_type=2, elem_type_2=2, comp_mode=1, size_control=1, skew_control=1, edge_mesh_type=14, min_size=0.0, max_size=0.0, max_deviation=0.0, max_angle=0.0, previous_settings=2, vertex_angle=25, )
