Model.freebodysectiondisplacement#
- Model.freebodysectiondisplacement(freebodysection_ids, freenode, arrlen=75.0, arroworigin=0, colorfx=3, colorfy=4, colorfz=5, colorfxy=1, colorfyz=2, colorfxz=7, colorfxyz=6, colormx=3, colormy=4, colormz=5, colormxy=1, colormyz=2, colormxz=7, colormxyz=6, createfield=0, createload=0, declim=2, display=1, displacement=0, fx=3, fxy=1, fxyz=6, fxz=7, fy=4, fyz=2, fz=5, mx=3, mxy=1, mxyz=6, mxz=7, my=4, myz=2, mz=5, resFileID=INT_MAX, resolvein_sys=0, resultID=Entity(), rotation=0, scid=0, scientific=0, showvalue=0, sizescale=0, stepid=0, tolerance=0.0001, userSysID=Entity(), vecstyle=0)#
Creates an FBD displacement plot and fields or loads from the results for a freebodysection entity with config=3 (FBD Plot). This queries the displacement data from the result entity on a freebodysection.
- Parameters:
freebodysection_ids (EntityList) – A list containing the freebodysection entity objects.
freenode (int) – Currently must be set to 2. This is a mandatory argument.
arrlen (double) – Controls the FBD plot arrow length. Default is 75 (%).
arroworigin (unsigned int) –
0 - Tail of arrow at node for the plot (default)
1 - Tip of arrow at node for the plot
colorfx (unsigned int) – The color of the Fx arrow. Valid values are 1-64.
colorfy (unsigned int) – The color of the Fy arrow. Valid values are 1-64.
colorfz (unsigned int) – The color of the Fz arrow. Valid values are 1-64.
colorfxy (unsigned int) – The color of the Fxy arrow. Valid values are 1-64.
colorfyz (unsigned int) – The color of the Fyz arrow. Valid values are 1-64.
colorfxz (unsigned int) – The color of the Fxz arrow. Valid values are 1-64.
colorfxyz (unsigned int) – The color of the Fxyz arrow. Valid values are 1-64.
colormx (unsigned int) – The color of the Mx arrow. Valid values are 1-64.
colormy (unsigned int) – The color of the My arrow. Valid values are 1-64.
colormz (unsigned int) – The color of the Mz arrow. Valid values are 1-64.
colormxy (unsigned int) – The color of the Mxy arrow. Valid values are 1-64.
colormyz (unsigned int) – The color of the Myz arrow. Valid values are 1-64.
colormxz (unsigned int) – The color of the Mxz arrow. Valid values are 1-64.
colormxyz (unsigned int) – The color of the Mxyz arrow. Valid values are 1-64.
createfield (unsigned int) –
0 - Do not create a nodal displacement field (default)
1 - Create a nodal displacement field
createload (unsigned int) –
0 - Do not create FBD displacement loads (default)
1 - Create FBD displacement loads
declim (int) – Controls the decimal limit. Default is 2.
display (unsigned int) –
0 - Do not plot FBD displacements
1 - Plot FBD displacements (default)
displacement (unsigned int) –
0 - Applied forces are not participating in the FBD calculation (default)
1 - Applied forces are participating in the FBD calculation
fx (unsigned int) –
0 - Fx translations are not included in the plot, load or field creation (default)
1 - Fx translations are included in the plot, load or field creation
0 - Fxy resultant translations are not included in the plot (default)
1 - Fxy resultant translations are included in the plot
0 - Fxyz resultant translations are not included in the plot (default)
1 - Fxyz resultant translations are included in the plot
0 - Fxz resultant translations are not included in the plot (default)
1 - Fxz resultant translations are included in the plot
fy (unsigned int) –
0 - Fy translations are not included in the plot, load or field creation (default)
1 - Fy translations are included in the plot, load or field creation
0 - Fyz resultant translations are not included in the plot (default)
1 - Fyz resultant translations are included in the plot
fz (unsigned int) –
0 - Fz translations are not included in the plot, load or field creation (default)
1 - Fz translations are included in the plot, load or field creation
mx (unsigned int) –
0 - Mx rotations are not included in the plot, load or field creation (default)
1 - Mx rotations are included in the plot, load or field creation
0 - Mxy resultant rotations are not included in the plot (default)
1 - Mxy resultant rotations are included in the plot
0 - Mxyz resultant rotations are not included in the plot (default)
1 - Mxyz resultant rotations are included in the plot
0 - Mxz resultant rotations are not included in the plot (default)
1 - Mxz resultant rotations are included in the plot
my (unsigned int) –
0 - My rotations are not included in the plot, load or field creation (default)
1 - My rotations are included in the plot, load or field creation
0 - Myz resultant rotations are not included in the plot (default)
1 - Myz resultant rotations are included in the plot
mz (unsigned int) –
0 - Mz rotations are not included in the plot, load or field creation (default)
1 - Mz rotations are included in the plot, load or field creation
resFileID (int) – The result file ID for resultid. Useful when multiple result files are loaded for a single result entity.
resolvein_sys (unsigned int) –
1 - Resolve in global system
2 - Resolve in user system
3 - Freebody section system
resultID (Entity) – The object describing the result entity.
rotation (unsigned int) –
0 - SPC forces are not participating in the FBD calculation (default)
1 - SPC forces are participating in the FBD calculation
scid (unsigned int) – The results subcase ID for result entity specified by resultid.
scientific (unsigned int) –
0 - Fixed format text (default)
1 - Scientific format text
showvalue (unsigned int) –
0 - Show text (default)
1 - Hide text
sizescale (unsigned int) –
0 - Constant FBD plot arrow length (default)
1 - Magnitude FBD plot arrow length
stepid (unsigned int) – The step/simulation ID for results subcase specified by scid.
tolerance (double) – The tolerance to limit the values. Default is 0.0001.
userSysID (Entity) – The object describing the system entity when
resolvein_sys =2.vecstyle (unsigned int) –
0 - 3D FBD plot arrow (default)
1 - 2D FBD plot arrow
Example#
Create an FBD Displacement plot#import hm import hm.entities as ent model = hm.Model() model.freebodysectiondisplacement( freebodysection_ids=[ent.Freebodysection(model, i) for i in range(1,4)], freenode=2, arrlen=75.0, arroworigin=0, colorfx=3, colorfy=4, colorfz=5, colorfxy=1, colorfyz=2, colorfxz=7, colorfxyz=6, colormx=3, colormy=4, colormz=5, colormxy=1, colormyz=2, colormxz=7, colormxyz=6, createfield=0, createload=0, declim=3, display=1, displacement=1, fx=3, fxy=0, fxyz=0, fxz=0, fy=1, fyz=0, fz=1, mx=0, mxy=0, mxyz=0, mxz=0, my=0, myz=0, mz=0, resFileID=2, resolvein_sys=3, resultID=ent.Result(model, 1), rotation=1, scid=1, scientific=0, showvalue=1, sizescale=0, stepid=0, tolerance=0.0001, userSysID=ent.System(model, 1), vecstyle=0, )
