Model.createCAERO2card#
- Model.createCAERO2card(start_id, system_id, origin_coordinate, length, n_int, n_slend, radii, theta, axis=1)#
Creates a body component of type CAERO2.
- Parameters:
start_id (int) – The ID from which the component and element numbering will start.
system_id (int) – The ID of the local coordinate system which the mesh will be generated based on. A value of 0 indicates the global coordinate system.
origin_coordinate (hwString) – The location of the origin. This must be 3 values enclosed in double quotes.
length (double) – The length along the x-axis of the coordinate system.
n_int (int) – The number of interference elements.
n_slend (int) – The number of slender body elements.
radii (hwString) – The radius at each interval along the length of the body. This must be the same number of values as given by
n_slend, and must be enclosed in double quotes.theta (hwString) – The angle along the radial direction of the body. This must be the same number of values as given by
n_int, and must be enclosed in double quotes.axis (int) –
1 - x-axis
2 - y-axis
3 - z-axis
Example#
Create a body component with ID 677771, system with ID 508, and considering the length along the y-axis of the coordinate system#import hm import hm.entities as ent model = hm.Model() # Creating collection containing node with ID 1 input_collection = hm.Collection(model, ent.Node, [1]) model.createCAERO2card( start_id=677771, system_id=508, origin_coordinate="1011.96772 124.925267 172.770859", length=500.0, n_int=6, n_slend=7, radii="0 40.0 40.0 50.0 60.0 60.0 80.0", theta="0 60.0 120.0 180.0 240.0 300.0", axis=2 )
