Model.addfacestocontactsurf#
- Model.addfacestocontactsurf(name, elem_collection, node_collection, break_angle, reverse_normals, face_or_edge)#
Adds elements using the face/edge option to a contact surface.
- Parameters:
name (hwString) – The name of the contact surface to update. User can directly supply a Python string.
elem_collection (Collection) – The collection containing the element entities to add.
node_collection (Collection) – The collection containing the node entities that define an edge or a face of an element.
break_angle (double) – The break angle for finding adjacent elements.
reverse_normals (int) –
Create contact surface. Valid values are:
0 - Along element normal.
1 - Opposite element normal.
face_or_edge (int) –
0 - On edge.
1 - On face.
Example#
Add elements with IDs 1 - 100 with faces defined by nodes with IDs 1 - 5 to contactsurf “ test “ with a break_angle of 30.0#import hm import hm.entities as ent model = hm.Model() # One-line version of collection using FilterByEnumeration elem_col = hm.Collection(model, ent.Element, list(range(1, 101))) # ID 1-100 node_col = hm.Collection(model, ent.Node, list(range(1, 6))) # ID 1-5 model.addfacestocontactsurf( name="test", elem_collection=elem_col, node_collection=node_col, break_angle=30.0, reverse_normals=0, face_or_edge=1, )
