Model.createnodesbetweennodes#
- Model.createnodesbetweennodes(node1, node2, number)#
Creates a user-specified number of nodes between two nodes.
- Parameters:
node1 (Entity) – The node entity of the first of 2 nodes between which new nodes should be created.
node2 (Entity) – The node entity of the second of 2 nodes between which new nodes should be created.
number (int) – The number of nodes which should be created between node1 and
node2.
Example#
Create 5 nodes between nodes with IDs 100 and 101#import hm import hm.entities as ent model = hm.Model() model.createnodesbetweennodes( node1=ent.Node(model, 100), node2=ent.Node(model, 101), number=5 )
