Model.createcollectorforpartiallycontained#
- Model.createcollectorforpartiallycontained(collection, name, config=0, type=0, reserved=0)#
Creates a collector and moves certain entities into the collector.
- Parameters:
collection (Collection) – The collection containing the input entities. Valid entities are elements, loads, systems and vectors
name (hwString) – The new collector name. The collector type is determined by the type of entities of the
collection.config (int) – Set to a valid config value to specify if only entities of that config should be moved. Otherwise, set to 0. Currently only supported for elements.
type (int) – Set to a valid type value to specify if only entities of that type should be moved. Otherwise, set to 0. Currently only supported for elements.
reserved (int) – Reserved for future development. Must be set to 0.
Examples#
Create a component named “comp2” and move elements with IDs 1-100#import hm import hm.entities as ent model = hm.Model() model.createcollectorforpartiallycontained( collection=hm.Collection(model, ent.Element, list(range(1, 101))), name="comp2", config=0, type=0, reserved=0, )
Create a component named “ comp2 “ and move only quad elements from elements 1-101#import hm import hm.entities as ent model = hm.Model() model.createcollectorforpartiallycontained( collection=hm.Collection(model, ent.Element, list(range(1, 101))), name="comp2", config=104, type=0, reserved=0, )
