Model.contactsurfcreatewithfacesusingfacenumber#
Model.contactsurfcreatewithfacesusingfacenumber(name, color, collection, face_number, reverse_normals, element_id, use_element_id)#
Creates a contact surface using 2D element edges or 2D/3D element faces.
Parameters:
  • name (hwString) – The name of the contact surface to create.
  • color (int) – The color of the contact surface. Valid values are 1 through 64.
  • collection (Collection) – The collection containing the element entities to use.
  • face_number (int) – The face number of the element (starting from 0).
  • reverse_normals (int) –
    0 - Create contact surface along element normal.
    1 - Create contact surface opposite element normal.
  • element_id (int) – The single element ID to use (default is 0).
  • use_element_id (int) –
    0 - Use collection (default).
    1 - Use element_id.
Example#
Create a contact surface named “test” with elements with IDs 1-100 using face number 3#
import hm
import hm.entities as ent
model = hm.Model()
model.contactsurfcreatewithfacesusingfacenumber(
    name="test",
    color=5,
    collection=hm.Collection(model, ent.Element, list(range(1, 101))),
    face_number=3,
    reverse_normals=0,
    element_id=0,
    use_element_id=0,
