Model.hm_getmoiofsolid#
- Model.hm_getmoiofsolid(solid, density=DBL_MAX)#
Return 6 values defining the moment and product of inertia values from the specified solid entity:
Ixx Iyy Izz Ixy Iyz Izx
These values will be calculated relative to the center of gravity/center of mass of the solid (obtained using
Model.hm_getcentroid()) and the global coordinate system “translated” to the COG. The user will specify the density value to use for the calculations.If a density is not given, then the returned values are the “mass normalized” values, where the MOI values are reported normalized by value of volume*1.0. The volume can be calculated using
volumedataname in a solid entity.- Parameters:
solid (Entity) – The object describing the solid entity.
density (double) – Density value of the solid. If specified, must be > 0.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:moiValues (numpy.ndarray)
Examples#
Get the “ true “ MOI for a solid with ID 10 and a density of 1e-9#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmoiofsolid(solid=ent.Solid(model, 10), density=10 ** (-9)) print("MOI values:", result.moiValues)
Get the “ mass normalized “ MOI for the solid with ID 10#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmoiofsolid(solid=ent.Solid(model, 10)) print("MOI values:", result.moiValues)
