Model.alternatefejointcreate#
- Model.alternatefejointcreate(type, node1, node2, system1, system2)#
Creates an FE joint element for use with the FE solution sequence. The elements can correspond to JOINT, MBPTCV, MBCVCV, MBPTDCV or MBPTDSF cards.
For type 42,
system1andsystem2must be specified asNone.For type 43, require
system1to be specified andsystem2may be specified asNone. And FE joint type 44 requires bothsystem1andsystem2should be specified.- Parameters:
type (int) –
The type of FE joint element. Valid values are:
42 - Ball.
system1andsystem2must be specified asNone.43 - Revolute.
system1is mandatory, butsystem2may be specified asNone.44 - Universal.
system1andsystem2must be specified.node1 (Entity) – The first FE joint node entity.
node2 (Entity) – The second FE joint node entity.
system1 (Entity) – The first FE joint system entity.
system2 (Entity) – The second FE joint system entity.
Example#
Create a ball FE joint connect nodes with IDs 10 and 25#import hm import hm.entities as ent model = hm.Model() model.alternatefejointcreate( type=42, node1=ent.Node(model, 10), node2=ent.Node(model, 25), system1=None, system2=None, )
