Model.hm_getclosestnode#
Model.hm_getclosestnode(x, y, z, elemCollection=Collection(), nodeCollection=Collection())#
Returns the closest node to the point (x,y,z). None is returned if there are no nodes in the database.
Parameters:
  • x (double) – The X coordinate of the input point.
  • y (double) – The Y coordinate of the input point.
  • z (double) – The Z coordinate of the input point.
  • elemCollection (Collection) – The collection containing the element entities. If elemCollection is given the algorithm only search nodes attached to elements (in components) on the collection.
  • nodeCollection (Collection) – The collection containing the node entities. If nodeCollection is given, algorithm ignores nodes on this collection when searching.
Returns:
Example#
Find the closest node to ( 0,0,0 ) on a quad4 element#
import hm
import hm.entities as ent
model = hm.Model()
element_collection = hm.Collection(model, ent.Element, "config=104")
_, result = model.hm_getclosestnode(x=0, y=0, z=0, elemCollection=element_collection)
print("Closest node to point:", result.closestNode.id)
