Model.blmesh_2d_input_bl#
- Model.blmesh_2d_input_bl(fixed_collection, float_collection)#
Specifies boundary layer input for
Model.blmesh_2d2(),Model.blmesh2d_computeblthickness()andModel.blmesh2d_computeblthickness1(). If this function is not called before either function, then all edges of the selected region are considered as boundary layer edges.If
Model.blmesh_2d_input_bl()is not called before either function, then all edges of the selected region are considered as boundary layer edges.- Parameters:
fixed_collection (Collection) –
The collection containing the entities for fixed non-boundary layer. Valid entity types depend on the
base_collectionvalue specified inblmesh_2d2()(or on the others mentioned in the description).If the entities in
base_collectionare surfaces, then the only valid entities in thefixed_collectionare lines.If the entities in
base_collectionare elements, then the only valid entities in thefixed_collectionare nodes or elements. For elements, only elements oftypename=PLOTELare allowed.float_collection (Collection) –
The collection containing the entities for float non-boundary layer. Valid entity types depend on the
base_collectionare surfaces, then the only valid entities in thefloat_collectionare lines.If the entities in
base_collectionare elements, then the only valid entities in thefloat_collectionare nodes or elements. For elements, only elements oftypename=PLOTELare allowed.
Examples#
Create a 5 layer boundary mesh with a quad dominated mesh of size 2.0 on surface with ID 10 , with the first layer be 0.15 thick and a growth rate of 1.2 , use boundary layer elements with IDs 10 and 11 as fixed and 12 and 13 as float , and non - boundary layer elements with IDs 1 and 2 as fixed and 5 and 6 as float#import hm import hm.entities as ent model = hm.Model() # Boundary layer elements blFixedEl_collection = hm.Collection(model, ent.Element, [10, 11]) blFloatEl_collection = hm.Collection(model, ent.Element, [12, 13]) model.blmesh_2d_input_bl( fixed_collection=blFixedEl_collection, float_collection=blFloatEl_collection ) # Non-Boundary layer elements nonBlFixedEl_collection = hm.Collection(model, ent.Element, [1, 2]) nonBlFloatEl_collection = hm.Collection(model, ent.Element, [5, 6]) model.blmesh_2d_input_nonbl( fixed_collection=nonBlFixedEl_collection, float_collection=nonBlFloatEl_collection ) # Generate the Boundary layer mesh base_surf_collection = hm.Collection(model, ent.Surface, [10]) model.blmesh_2d2( base_collection=base_surf_collection, num_layers=5, first_layer_thickness=0.15, growth_rate=1.2, element_size=2.0, element_type="quads", )
Create a 5 layer boundary mesh from elements with IDs 10 - 100 , with the first layer be 0.15 thick and agrowth_rateof 1.2 , acore_to_BL_ratioof 2.5 , acorner_factorof 1.1 , and use non - boundary layer elements with ID 1 and 2 as fixed and 5 and 6 as float#import hm import hm.entities as ent model = hm.Model() # Non-Boundary layer elements nonBlFixedEl_collection = hm.Collection(model, ent.Element, [1, 2]) nonBlFloatEl_collection = hm.Collection(model, ent.Element, [5, 6]) model.blmesh_2d_input_nonbl( fixed_collection=nonBlFixedEl_collection, float_collection=nonBlFloatEl_collection ) # Generate the Boundary layer mesh base_elem_collection = hm.Collection(model, ent.Element, list(range(10, 101))) model.blmesh_2d_computeblthickness( base_collection=base_elem_collection, num_layers=5, first_layer_thickness=0.15, growth_rate=1.2, core_to_BL_ratio=2.5, corner_factor=1.1, )
