Model.parsesolveroutputfile#
- Model.parsesolveroutputfile(filename, filetype='f06', extractdata='fluttercurves')#
Creates tables from solver output files.
- Parameters:
filename (hwString) – The full name and path of the file to parse.
filetype (hwString) – The type of file to parse. Valid values are F06.
extractdata (hwString) –
The type of data to extract from the file. Valid values are:
fluttercurves - Collects flutter summary data and creates tables for pk and pknl methods.
Example#
Generate tables from the flutter data contained in the file “ C:/temp / MSCFlutter.out “#import hm import hm.entities as ent model = hm.Model() model.parsesolveroutputfile( filename="C:/temp/MSCflutter.out", filetype="F06", extractdata="fluttercurves" )
