Model.xyplotchangemode#
- Model.xyplotchangemode(plotname, mode)#
Changes the mode of an extended plot.
- Parameters:
plotname (hwString) – Name of the extended (dual) plot to change.
mode (int) –
Mode in which data will be displayed. Valid options are:
2 - Complex mode.
5 - Phase/Magnitude mode.
Note
Extended (or dual) plots can display data in two modes. In complex mode, (
mode=2), the Y-axis of the bottom plot is the real component, while the Y-axis of the top plot is the imaginary component. In phase/magnitude mode (mode=5), the Y-axis of the bottom plot is magnitude (in logarithmic form), while the Y-axis of the top plot is phase. Other mode indices (besides 2 and 5) are reserved for future use.Example#
Change the mode of plot with name * results * to * Phase / Magnitude *#import hm import hm.entities as ent model = hm.Model() model.xyplotchangemode(plotname="results", mode=5)
