Model.hm_getsketchdata#
- Model.hm_getsketchdata(entity_id=0, entity_type='none', id=0, sketchdata='', name='', file_name='')#
Queries the information about the entities present in the sketch data.
- Parameters:
entity_id (int) – nan
entity_type (hwString) – The type of queried entity present in the sketch.
id (int) – The ID of the sketch entity. Provided if
nameis not provided.sketchdata (hwString) – The queried sketch entity data name.
name (hwString) – The name of the sketch entity. Provided if
idis not provided.file_name (hwString) – Reserved for future development. Should be set to “”.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:Keys valid for
sketchdata="entity_list"result (numpy.ndarray)
Keys valid for
sketchdata="type"result (list of strings)
Keys valid for
sketchdata="start_position"result (numpy.ndarray)
Keys valid for
sketchdata="is_fixed"result (numpy.ndarray)
Keys valid for
sketchdata="is_construction"result (numpy.ndarray)
Keys valid for
sketchdata="point_position"result (numpy.ndarray)
Keys valid for
sketchdata="line_position"result (numpy.ndarray)
Keys valid for
sketchdata="line_direction"result (numpy.ndarray)
Keys valid for
sketchdata="end_position"result (numpy.ndarray)
Keys valid for
sketchdata="start_point"result (numpy.ndarray)
Keys valid for
sketchdata="end_point"result (numpy.ndarray)
Keys valid for
sketchdata="length"result (numpy.ndarray)
Keys valid for
sketchdata="angle"result (numpy.ndarray)
Keys valid for
sketchdata="is_bounded"result (numpy.ndarray)
Keys valid for
sketchdata="center_position"result (numpy.ndarray)
Keys valid for
sketchdata="center_point"result (numpy.ndarray)
Keys valid for
sketchdata="radius"result (numpy.ndarray)
Keys valid for
sketchdata="start_angle"result (numpy.ndarray)
Keys valid for
sketchdata="end_angle"result (numpy.ndarray)
Keys valid for
sketchdata="sweep_angle"result (numpy.ndarray)
Keys valid for
sketchdata="is_counterclockwise"result (numpy.ndarray)
Keys valid for
sketchdata="major_radius"result (numpy.ndarray)
Keys valid for
sketchdata="minor_radius"result (numpy.ndarray)
Keys valid for
sketchdata="vertical_axis"result (numpy.ndarray)
Keys valid for
sketchdata="degree"result (numpy.ndarray)
Keys valid for
sketchdata="is_periodic"result (numpy.ndarray)
Keys valid for
sketchdata="is_interpolated"result (numpy.ndarray)
Keys valid for
sketchdata="is_externalref"result (numpy.ndarray)
Keys valid for
sketchdata="pattern_type"result (list of strings)
Keys valid for
sketchdata="number_directions"result (numpy.ndarray)
Keys valid for
sketchdata="pattern_angle"result (numpy.ndarray)
Keys valid for
sketchdata="dir1_distance"result (numpy.ndarray)
Keys valid for
sketchdata="dir2_distance"result (numpy.ndarray)
Keys valid for
sketchdata="dir1_copies_count"result (numpy.ndarray)
Keys valid for
sketchdata="dir2_copies_count"result (numpy.ndarray)
Keys valid for
sketchdata="constraint_type"result (list of strings)
Keys valid for
sketchdata="constraint_entities"result (numpy.ndarray)
Keys valid for
sketchdata="variable_name"result (list of strings)
Keys valid for
sketchdata="dim_value"result (numpy.ndarray)
Keys valid for
sketchdata="is_dimdriven"result (numpy.ndarray)
Keys valid for
sketchdata="is_dimension"result (numpy.ndarray)
Keys valid for
sketchdata="spline_points"result (numpy.ndarray)
Keys valid for
sketchdata="spline_positions"result (numpy.ndarray)
Example#
Query the list of point IDs from sketch ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getsketchdata(id=1, entity_type="point", sketchdata="entitylist") print("List of point ids:", result.result)
