Model.defaultremeshsurf#
Model.defaultremeshsurf(collection, elem_size, elem_type, elem_type_2, previous_settings, comp_mode, size_control, skew_control, mesh_type, min_size, max_size, chordal_dev, max_angle)#
Re-meshes a selection of surfaces using saved or default parameters and various options, and deletes any elements already meshed on those surfaces.
Parameters:
  • collection (Collection) – The collection containing the surface entities to re-mesh.
  • elem_size (double) – The default element size used to calculate element densities along edges (when necessary).
  • elem_type (int) –
    Flag indicating the elements generated for mapped meshing algorithms. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    4 - quads only
  • elem_type_2 (int) –
    Flag indicating the elements generated for free meshing algorithms. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    4 - quads only
  • previous_settings (int) –
    Flag indicating whether to break, keep or redo connectivity between neighboring surfaces. Valid values are:
    0 - Keep previous settings and do not break connectivity between neighboring surfaces.
    1 - Break connectivity between neighboring surfaces.
    2 - Keep connectivity between neighboring surfaces.
    3 - Redo connectivity between neighboring surfaces by expanding surface selection by one layer of adjacent surfaces.
  • comp_mode (int) –
    Parameter specifying how entities are organized into components. Valid options are:
    0 - Elements are created in the current component.
    1 - Elements are created in the same components as their parent surfaces.
  • size_control (int) –
    Flag indicating whether to create uniformly sized elements. Valid options are:
    0 - Do not create uniformly sized elements.
    1 - Create uniformly sized elements.
  • skew_control (int) –
    Flag indicating whether to create optimally shaped elements when using mapping algorithms. Valid options are:
    0 - Do not create optimally shaped elements.
    1 - Create optimally shaped elements.
  • mesh_type (int) –
    Parameter specifying the meshing algorithm for edge/surface meshing. Valid options are:
    1 - Standard edge meshing.
    2 - Chordal deviation edge meshing.
    3 - Proximity based surface meshing.
    4 - Proximity and curvature based surface meshing.
    5 - Curvature based surfaced meshing.
    6 - Proximity and curvature based meshing with free edge deviation.
    7 - Curvature based surface meshing with free edge deviation.
    11 - Standard edge meshing with flow “align” control.
    12 - Chordal deviation edge meshing with flow “align” control.
    14 - Standard edge meshing with flow “align” and “size” control.
  • min_size (double) – The minimum edge size for chordal deviation meshing. Ignored otherwise.
  • max_size (double) – The maximum edge size for chordal deviation meshing. Ignored otherwise.
  • chordal_dev (double) – The chordal deviation value for chordal deviation meshing. Ignored otherwise.
  • max_angle (double) – The maximum angle (in degrees) between edges for chordal deviation meshing. Ignored otherwise.
Example#
Re-meshing using quads using a default edge size of 1.0 for the surface with ID 3#
import hm
import hm.entities as ent
model = hm.Model()
inp_col = hm.Collection(model, ent.Surface, [3])
model.defaultremeshsurf(
    collection=inp_col,
    elem_size=1.0,
    elem_type=1,
    elem_type_2=1,
    previous_settings=1,
    comp_mode=0,
    size_control=0,
    skew_control=0,
    mesh_type=1,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
Re-meshing using mixed type elements for the size controlled mapping algorithm using tria transitions, trias for free mesh and chordal deviation edge meshing for surfaces 3, 5 and 6#
import hm
model = hm.Model()
inp_col = hm.Collection(model, ent.Surface, [3, 5, 6])
    collection=inp_col,
    elem_size=1.0,
    elem_type=1,
    elem_type_2=0,
    comp_mode=0,
    size_control=1,
    skew_control=0,
    mesh_type=1,
    min_size=0.5,
    max_size=30.0,
    chordal_dev=0.1,
    max_angle=15.0,
