Model.CE_DetailSetUint#
Model.CE_DetailSetUint(ce_id, detailName, uint_val, unknownFlag, force_storage_flag)#
Sets an unsigned integer as connector detail for a connector specified by ID.
Parameters:
  • ce_id (unsigned int) – ID of the connector to which you wish to attach detail.
  • detailName (hwString) – Name for a user-defined unsigned integer detail.
  • uint_val (unsigned int) – The unsigned integer value for the detail.
  • unknownFlag (unsigned int) – Reserved for future development. Must be set to 0.
  • force_storage_flag (unsigned int) –
    The flag indicating whether or not to store a user-defined detail.
    0 - No
    1 - Yes
Example#
Set a user-defined unsigned integer detail “test = 2.0” for connector with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
model.Model.CE_DetailSetUint(
    ce_id=1, detailName="test", uint_val=2.0, unknownFlag=0, force_storage_flag=1
Note
There are currently no standard unsigned integer details, only user-defined ones.
