Model.section_plane_mesh#
Model.section_plane_mesh(collection, mesh_type, elem_size, connectivity, elem_collection, tol)#
Generates a shell mesh from a selection of planar boundary elements.
Parameters:
  • collection (Collection) – The collection containing the entities to use as input for the boundary.Valid entities are component entities and element entities.
  • mesh_type (int) –
    Flag indicating the type of mesh to generate. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    4 - quads only
  • elem_size (double) – The target element size.
  • connectivity (int) –
    Manage the connection with input boundary/overlay elements. Valid values are:
    0 - Generate mesh using given element size. Ignore elem_mark_id.
    1 - Manage connection with the user given boundary elements. Ignore elem_mark_id.
    2 - Manage connection with elements specified with elem_mark_id. Elements on elem_mark_id should be part of collection as well.
    3 - Manage connection with boundary elements which are not on elem_mark_id.
    4 - Manage connection with overlapped elements on elem_mark_id. Overlapped elements should not be tagged as boundary elements on collection.
    5 - Manage connection with boundary elements which do not overlap elem_mark_id elements. Overlapped elements should not be tagged as boundary elements on collection.
  • elem_collection (Collection) – The collection containing the element entities used to manage the connectivity.
  • tol (double) – The tolerance to use for overlay check. If set as 0, the tolerance will attempt to be automatically detected.
Example#
Create a section plane quad mesh of size 2.0 , use the elements with IDs 10 - 30 as boundary input , and the elements with IDs 1 - 5 as overlapped#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains the elements used as boundary input
filter_input_elements = hm.FilterByEnumeration(ent.Element, list(range(10, 31)))
input_elements_collection = hm.Collection(model, filter_input_elements)
# Creating a collection that contains the elements used as overlapped
filter_overlapped_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 6)))
overlapped_elements_collection = hm.Collection(model, filter_overlapped_elements)
model.section_plane_mesh(
    collection=input_elements_collection,
    mesh_type=1,
    elem_size=2.0,
    connectivity=4,
    elem_collection=overlapped_elements_collection,
    tol=0.0,
