Model.CE_AddLinkEntitiesDirectByRule#
- Model.CE_AddLinkEntitiesDirectByRule(collection, link_type, link_rule, link_state, link_string_array, extra_link_integer_array, create_group)#
Allows the user to add link directly to the connectors without considering tolerance or number of layers.
- Parameters:
collection (Collection) – The collection containing the connector entities to update.
link_type (EntityFullType) – The entity type to be added to the connectors as links.
link_rule (unsigned int) –
The rule by which the link entity is added to the connector. If the rule is specified, the modification is performed in accordance with the rule. For example, a value of 2 requires link IDs to be specified for
link_string_array. Valid values are:0 - Undefined
1 - None
2 - Use ID
3 - Use Name
4 - Proximity
5 - Use UID
link_state (unsigned int) –
The state of the link entity which is to be added:
0 - Undefined
1 - Elems
2 - Geom
link_string_array (hwStringList) – A list of strings containing the list of link IDs/names/UIDs to be added directly to connectors. The strings are generally IDs/names/UIDs based on the
link_rule.extra_link_integer_array (hwIntList) – A list of integers containing the list of extra link additions allowed for spots and seams. The integers are generally IDs/UIDs based on the
link_rule.create_group (unsigned int) –
0 - Add the newly chosen links separately to the connector
1 - Add the newly chosen links as a group to the connector
Example#
Add two component links (ID 1 and 2) directly to connector with ID 2 of type spot using without creating a group link#import hm import hm.entities as ent model = hm.Model() model.CE_AddLinkEntitiesDirectByRule( collection=hm.Collection(model, ent.Connector, [1, 2]), link_type=ent.Component, link_rule=2, link_state=1, link_string_array=["1", "2"], extra_link_integer_array=["2", "2"], create_group=0, )
