Model.dummyplacerootbodytopoint#
Model.dummyplacerootbodytopoint(name, sx, sy, sz, tx, ty, tz, tolerance)#
Moves a dummy from a source point to a target point.
The mechanism must have the enabled flag set to true for this to be possible.
Parameters:
  • name (hwString) – The name of the root body of the dummy.
  • sx (double) – The x-coordinate of the source point. This is usually the x-coordinate of the H-Point of the dummy.
  • sy (double) – The y-coordinate of the source point. This is usually the y-coordinate of the H-Point of the dummy.
  • sz (double) – The z-coordinate of the source point. This is usually the z-coordinate of the H-Point of the dummy.
  • tx (double) – The x-coordinate of the target point.
  • ty (double) – The y-coordinate of the target point.
  • tz (double) – The z-coordinate of the target point.
  • tolerance (double) – The tolerance allowed during the placement.
Example#
Move a dummy with root body named “ Pelvis Angle Gauge “ from ( 0.0,0.0,0.0 ) to ( 150.0,100.0,200.0 )#
import hm
import hm.entities as ent
model = hm.Model()
model.dummyplacerootbodytopoint(
    name="Pelvis Angle Gauge",
    sx=0.0,
    sy=0.0,
    sz=0.0,
    tx=150.0,
    ty=100,
    tz=200,
    tolerance=0.001,
