Model.CE_FE_RegisterSharedEntities#
- Model.CE_FE_RegisterSharedEntities(connector, existing_entities)#
Registers pre-existing entities to a single connector.
Note that a single entity can be registered with multiple connectors.
- Parameters:
connector (Entity) – The object describing the connector entity to register to.
existing_entities (CollectionSet) – The set of collections containing possibly multiple type of entities.
Example#
Register pre-existing FE to connector with ID 10#import hm import hm.entities as ent model = hm.Model() # First, change connector 10 to the user control mode: model.CE_SetSpecificDetailById(ce_id=10, detail_type=2, int_val=1, dbl_val=0) # Second, create the necessary collection set to register collections of multiple types of entities: collection_set = hm.CollectionSet(model) # Create collection of component entity with ID 3 and add to collection set: component_1 = hm.Collection(model, ent.Component, [3]) collection_set.set(component_1) # Create collection of property entity with ID 7 and add to collection set: property_1 = hm.Collection(model, ent.Property, [7]) collection_set.set(property_1) # Create collection of material entity with ID 8 and add to collection set: material_1 = hm.Collection(model, ent.Material, [8]) collection_set.set(material_1) # Create collection of set entity with ID 12 and add to collection set: set_1 = hm.Collection(model, ent.Set, [12]) collection_set.set(set_1) # Create collection of group entity with ID 14 and add to collection set: group_1 = hm.Collection(model, ent.Group, [14]) collection_set.set(group_1) # Third, register the entities with connector 10: model.CE_FE_RegisterSharedEntities( connector=ent.Connector(model, 10), existing_entities=collection_set ) # Finally, turn the user control mode off for connector 10 (optional): model.CE_SetSpecificDetailById(ce_id=10, detail_type=2, int_val=0, dbl_val=0)
