Model.includesuppressactive#
Model.includesuppressactive(include_id, include_shortname, state)#
Sets the active/inactive state of all supported entities contained within the include file (but not the include file itself) with include_id and include_shortname. Only one of these two options need to be specified, however include_id will take precedence if specified. Double quotes “” must be used for an argument that is not specified.
Include files do not have an active/inactive state, only the entities contained within them.
Parameters:
  • include_id (unsigned int) – The ID of the include file.
  • include_shortname (hwString) – The (short) name of the include file
  • state (int) –
    The state argument indicates the active/inactive status for the supported entities contained in the include. Valid values are:
    0 - Indicates to set the entities to active and turn on their display.
    1 - Indicates to set the entities to inactive and remove them from the display.
    2 - Indicates to set the entities to active but not to re-display them.
Examples#
Set all supported entities contained within include file ID 5 to active and re - display#
import hm
import hm.entities as ent
model = hm.Model()
model.includesuppressactive(include_id=5, include_shortname="", state=0)
Set all supported entities contained within include file shortname “ include.txt “ to inactive#
import hm
model = hm.Model()
model.includesuppressactive(include_id=None, include_shortname="include.txt", state=1)
Set all supported entities contained within include file ID 5 to active and not re - display#
import hm
model = hm.Model()
model.includesuppressactive(include_id=5, include_shortname="", state=2)
