Model.linearsurfacebetweennodes#
- Model.linearsurfacebetweennodes(list1, list2, reverse, closed=0, setmeshparam=0)#
Creates a ruled surface between two node lists. Optionally it can immediately be use within the automesher. It can also identify a region in the shape of a ruled surface for the automesher to use under the mesh without surface option.
- Parameters:
list1 (EntityList) – The first list of node entities forming one side of the surface.
list2 (EntityList) – The second list of node entities forming one side of the surface.
reverse (int) –
Indicates whether the lines should be tested for a “bow tie” condition and reversed if necessary. Valid options are:
0 - No testing the lines for a “bow tie” condition and no reversing.
1 - Testing the lines for a “bow tie” condition and reversing.
closed (int) – Flag defining if the node selection should be treated as a closed loop (1 for yes, 0 for no).
setmeshparam (int) – Flag defining if the mesh parameter is set for the orphan nodes selection (1 for yes, 0 for no).
Example#
Identify a region in the shape of a ruled surface and sends it into the automesher to create quad elements and store the elements to the HyperMesh database#import hm import hm.entities as ent model = hm.Model() ''' Indentifying a region in the shape of a ruled surface using the model.surfacemode(mode=3), the model.linearsurfacebetweennodes() and sends it into the automesher via the model.set_meshedgeparams() to create quad elements via model.linearmesh(quads=1). The model.storemeshtodatabase() stores the elements in Hypermesh database ''' model.surfacemode(mode=3) nodelist1 = [ ent.Node(model, 1581), ent.Node(model, 77), ent.Node(model, 83), ent.Node(model, 88), ent.Node(model, 95), ] nodelist2 = [ ent.Node(model, 225), ent.Node(model, 228), ent.Node(model, 232), ent.Node(model, 235), ent.Node(model, 262), ] model.linearsurfacebetweennodes(list1=nodelist1, list2=nodelist2, reverse=1) model.set_meshedgeparams( edge_index=0, elem_density=8.0, alg_type=1, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=1, elem_density=4.0, alg_type=1, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=2, elem_density=8.0, alg_type=1, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=3, elem_density=4.0, alg_type=1, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.linearmesh(quads=1) model.storemeshtodatabase(elemstosurfcomp=0) model.ameshclearsurface()
