Model.CE_ConnectorCreateByAutopitchNew#
- Model.CE_ConnectorCreateByAutopitchNew(collection, maxProximityDistance, autopitchInterval, autopitchToEdgeDistance, autopitchFeatureEdgeDistance, autopitchOffset=0, considerThinSolids=1, createPointsInMiddle=0, featureAngle=180, maxFlangeWidth=0, maxVariationPercent=0, combineSpots=0, maxLinks=2, excludeHolesWithWidthLessThan=0)#
Create connectors using autopitch points, obtained by flange detection techniques.
- Parameters:
collection (Collection) – The collection containing the component entities to find flanges in, to create connectors.
maxProximityDistance (double) – The maximum proximity distance that can be used. Also, used as the tolerance value for connector creation.
autopitchInterval (double) – Spacing between autopitch points. Points are not created if set to 0.0.
autopitchToEdgeDistance (double) – The distance from the free edge for autopitch points.
autopitchFeatureEdgeDistance (double) – The distance from the feature edges for autopitch points.
autopitchOffset (double) – The initial offset for autopitch point. If set to 0.0,
autopitch_interval/2is used.considerThinSolids (unsigned int) –
0 - Closed shell thin solids are not considered as input. Only standard shell midmeshes are considered.
1 - Closed shell thin solids are considered as input, along with standard shell midmeshes.
createPointsInMiddle (unsigned int) –
0 - Autopitch points are created on one of the flanges
1 - Autopitch points are created at the midplane of flanges
featureAngle (double) – Used to identify each connected sequence of feature edges. Specifically, a feature edge is one whose adjoining faces form an angle greater than this value. Acceptable values are [0.0, 180], otherwise closer extreme is used.
maxFlangeWidth (double) – The maximum flange width. Used only if it is greater than 0.0.
maxVariationPercent (double) – The maximum percentage variation allowed in inter-flange distances, from the average inter-flange distance.
combineSpots (int) – Reserved for future development
maxLinks (int) – Reserved for future development
excludeHolesWithWidthLessThan (double) – Reserved for future development
Example#
Create connectors at the midplane of the components with IDs 1 and 2 using a feature angle of 30.0 degrees, not considering closed shell thin solids as input, maximum flange width of 20.0, maximum proximity distance of 20.0, autopitch interval of 50.0, offset of 10.0, a distance from free edge of 10.0, with 0 maximum percentage variation allowed in inter-flange distances and a distance from the feature edges of 5.0#import hm import hm.entities as ent model = hm.Model() model.CE_ConnectorCreateByAutopitchNew( collection=hm.Collection(model, ent.Component, [1, 2]), maxProximityDistance=20.0, autopitchFeatureEdgeDistance=5.0, autopitchInterval=50.0, autopitchToEdgeDistance=10.0, autopitchOffset=10.0, considerThinSolids=0, createPointsInMiddle=1, featureAngle=30.0, maxFlangeWidth=20.0, maxVariationPercent=0.0, )
