Model.linearsolidsbynodelist#
- Model.linearsolidsbynodelist(collection1, collection2, align1, align2, align3, align4, align5, align6, nodelist)#
Creates solid elements between two groups of plane elements, with the layers identified by nodes in a node list.
- Parameters:
collection1 (Collection) – The collection containing the element entities of the first group of plate elements.
collection2 (Collection) – The collection containing the element entities of the second group of plate elements.
align1 (Entity) – The node entity to be used as an alignment node for the first group of elements.
align2 (Entity) – The node second to be used as an alignment node for the first group of elements.
align3 (Entity) – The node entity to be used as an alignment node for the first group of elements.
align4 (Entity) – The node entity to be used as an alignment node for the second group of elements.
align5 (Entity) – The node entity to be used as an alignment node for the second group of elements.
align6 (Entity) – The node entity to be used as an alignment node for the second group of elements.
nodelist (EntityList) – The list with the node entities to be used to specify the locations of the layers.
Example#
Create 8 layers of solids between plate elements with IDs 10 , 11 , 12 , 13 and 20 , 21 , 22 , 23 use , as alignment nodes , nodes with IDs 5 and 13 , and as layer - specify nodes with IDs 5 , 6 , 7 , 8 , 9 , 10 , 11 , 12 , 13#import hm import hm.entities as ent model = hm.Model() model.linearsolidsbynodelist( collection1=hm.Collection(model, ent.Element, [10, 11, 12, 13]), collection2=hm.Collection(model, ent.Element, [20, 21, 22, 23]), align1=ent.Node(model, 5), align2=None, align3=None, align4=ent.Node(model, 13), align5=None, align6=None, nodelist=[ ent.Node(model, 5), ent.Node(model, 6), ent.Node(model, 7), ent.Node(model, 8), ent.Node(model, 9), ent.Node(model, 10), ent.Node(model, 11), ent.Node(model, 12), ent.Node(model, 13), ], )
Note
The
nodelistnodes should begin with one belonging to an element on thecollection1and end with a corresponding one belonging to an element on thecollection2
