Model.fill_fe_holes_lines#
- Model.fill_fe_holes_lines(collection, max_width, ByFeature=0, Remesh=0, DefineMaxWidth=0, AdjacentComp=0, CurvedFill=0, GuideNodePairs=hwIntList(), DetectNodeClusters=0, DoOverlapCleanup=0, CheckForDuplicate=0)#
Fills FE holes from a line selection defining the holes.
- Parameters:
collection (Collection) – The collection containing the entities.
max_width (double) – Maximum allowed hole width.
ByFeature (int) –
0 - Features should not be considered.
1 - Features should be considered.
Remesh (int) –
0 - Fill elements should not be remeshed.
1 - Fill elements should be remeshed.
DefineMaxWidth (int) –
0 - Ignore max_width for hole filling.
1 - Consider max_width for hole filling.
AdjacentComp (int) –
0 - Fill elements should be created in a new component.
1 - Fill elements should be created in the adjacent component.
2 - Fill elements should be created in the current component.
CurvedFill (int) –
0 - Gaps are filled without taking into consideration the shape of adjacent elements.
1 - Gaps are filled taking into consideration the shape of adjacent elements, ensuring a smooth fill.
GuideNodePairs (hwIntList) – Reserved for future development. Value must be 0.
DetectNodeClusters (int) – Reserved for future development. Value must be 0.
DoOverlapCleanup (int) – Reserved for future development. Value must be 0.
CheckForDuplicate (int) – Reserved for future development. Value must be 0.
Example#
Fill the holes defined by the closed lines with IDs 1-5, using a max width of 20.5, remeshing filled elements, and creating the elements in the adjacent components#import hm import hm.entities as ent model = hm.Model() model.fill_fe_holes_lines( collection=hm.Collection(model, ent.Line, list(range(1,6))), max_width=20.5, Remesh=1, DefineMaxWidth=1, AdjacentComp=1 )
