Model.hm_ce_linkprojectionorderget_byentity#
- Model.hm_ce_linkprojectionorderget_byentity(entity, option)#
Returns ordered projection information from links of spot connectors.
- Parameters:
entity (Entity) – The connector entity to query.
option (unsigned int) –
0 - Return stored projection information with spot connector
1 - Redo projection for spot connector and return projection information
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:connector (Entity) - Entity Type:
ConnectornumberOfLayers (int)
listOfLayerDetails (
HmQueryResultList)-Result list object containingHmQueryResultobjects with the following output data:index1 (int)
index2 (int)
projectionLocation (numpy.ndarray)
element (Entity) - Entity Type:
Element
Example#
Get projection information from spot connector with ID 101#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_ce_linkprojectionorderget_byentity( entity=ent.Connector(model,101), option=1 ) print("Connector ID:", result.connector.id) print("No of Layers:", result.numberOfLayers) proj_infos = result.listOfLayerDetails for info in proj_infos: print("Layer index 1:", info.index1) print("Layer index 2:", info.index2) print("Projection Location:", info.projectionLocation) print("Element ID:", info.element.id)
