Model.hm_info#
Model.hm_info(option)#
Returns general information about HyperMesh session.
Parameters:
option (hwString) – The name of the information to retrieve. Valid values are currentinclude, currentfile, database_empty, database_modified, geomstyle, istemplateloaded, reviewmode, templatecodename, templatefilename, templateid, templatetype, tempnam, writeviewcommands.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • Keys valid for option="currentinclude"
      • info_value (str) - The current include file shortname.
    • Keys valid for option="currentfile"
      • info_value (str) - The full path and file name of the current HyperMesh database.
    • Keys valid for option="database_empty"
      • info_value (Bool) - Indicates whether the database is empty.
    • Keys valid for option="database_modified"
      • info_value (Bool) - Indicates whether the database has been modified.
    • Keys valid for option="geomstyle"
    • Keys valid for option="istemplateloaded"
      • info_value (Bool) - Indicates whether a template is loaded.
    • Keys valid for option="reviewmode"
    • Keys valid for option="templatecodename"
      • info_value (int) - The current template code identifier. Solver identifiers 0-63 are reserved for HyperMesh officially supported templates. Solver identifiers 64-127 inidicate a user-defined template.
    • Keys valid for option="templatefilename"
      • info_value (str) - Full path and file name of the current tempate file.
    • Keys valid for option="templateid"
      • info_value (int) - The current template ID.
    • Keys valid for option="templatetype"
      • info_value (str) - Current template type. This is one of the predefined template types, currently one of the following: nastran, abaqus, autodv, hyperopt, pamcrash, patran, ansys, lsdyna, simex, phlex, pdm, mainfile, or none. Some template type names are not reported.
    • Keys valid for option="tempnam"
      • info_value (str) - Full path and file name of a temporary file. The value returned from each call is unique.
    • Keys valid for option="writeviewcommands"
      • info_value (Bool) - Indicates whether view commands are written.
Example#
Get the path of the current HyperMesh database#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_info("currentfile")
print(result.info_value)
Check if the current database has been modified#
import hm
model = hm.Model()
_, result = model.hm_info("database_modified")
if result.info_value:
    print("The database has been modified.")
else:
    print("The database has not been modified.")
