Model.hm_getmodelcheckcorrectiondisplayname#
- Model.hm_getmodelcheckcorrectiondisplayname(check_display_name)#
Returns the correction names for a given check.
- Parameters:
check_display_name (hwString) – The GUI display name of the check. This is case sensitive.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:correctionDisplayName (str)
Example#
Get the correction names for the “ Unused materials “ check#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckcorrectiondisplayname( check_display_name="Unused materials" ) print("correctionDisplayName:", result.correctionDisplayName)
