Model.segmentsetcreateusingfacenumber#
- Model.segmentsetcreateusingfacenumber(name, color, collection, face_number, reverse_normals, element_id, option)#
Creates a segment set using 2D element edges or 2D/3D element faces.
- Parameters:
name (hwString) – The name of the segment set to create.
color (int) – The color of the segment set. Valid values are 1-64.
collection (Collection) – The collection containing the element entities to use.
face_number (int) – The face number of the element (starting from 0).
reverse_normals (int) –
Create segment set:
0 - Along element normal
1 - Opposite element normal
element_id (int) – If non-zero, specifies the single element to use instead of
collection.option (int) – If non-zero, specifies to use
element_idinstead ofcollection.
Example#
Create a segment set named “ test “ with elements with IDs 1 - 100 useface_number=3:#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the elements to use filter_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 101))) elements_collection = hm.Collection(model, filter_elements) model.segmentsetaddfacesusingfacenumber( name="test", color=5, collection=elements_collection, face_number=3, reverse_normals=0, element_id=1, option=0, )
