Model.imprint_nodelist#
Model.imprint_nodelist(list_source, collection_target, options)#
Imprints, connects and optionally remeshes source segments defined by a node list onto target 2D elements.
Parameters:
  • list_source (EntityList) – A list containing the source node entities defining the segments to imprint.
  • collection_target (Collection) – The collection containing the target entities to imprint onto. Valid entities are components and elements.
  • options (hwString) –
    Additional strings defining extended parameters/options. Options are defined in "name value(s)" format. Valid options are:
    • projection_vector xyz
    The 3 doubles defining the vector direction. If not defined, normal projection is used.
    • remain value
    1 - Source remains, source node coordinates are kept (default if not provided).
    2 - Destination remains, node coordinates projected to destination are used.
    3 - Both remain, source entities are projected and a copy is imprinted to destination.
    • max_distance value
    The function will exit with an error if the distance between source and destination exceeds this value. If not specified, this is ignored.
    • to_dest_component value
    0 - Do not organize imprinted elements to destination component (default if not provided).
    1 - Organize imprinted elements to destination component.
    • angle value
    The angle used to define feature edges on the mesh. If not defined, 25.0 is used.
    • remesh_mode value
    -1 - No remesh. Element connectivity is maintained by recovery of the imprinting element edges.
    0 - Do not remesh destination. Destination mesh is stitched to maintain element connectivity.
    1 - Remesh all input destination elements.
    2 - Remesh destination elements defined by remesh_layers.
    • remesh_layers value
    Must be defined if remesh_mode is set to 2.
    0 - Remesh only the elements attached to the border of the imprinted element image.
    > 0 - Remesh additional layers in addition to the elements attached to the imprinted element image.
    • mesh_type value
    Automatically detected from input mesh if not provided.
    0 - tria
    1 - quad
    2 - mixed
    3 - R-tria
    4 - quad only
    • mesh_size value
    • create_joint_elems value
    Only valid when remain is set to 3.
    0 - Do not generate patch elements between source segments and destination elements (default if not provided).
    1 - Generate patch elements between source segments and destination elements.
    • close_node_list value
    0 - Do not generate a segment between the last node and the first node to close the list as a loop (default if not provided).
    1 - Generate a segment between the last node and the first node to close the list as a loop.
Example#
Imprint the segments defined by a list of nodes with IDs 1-4 onto the elements in component “destination”#
import hm
import hm.entities as ent
model = hm.Model()
node_list = [
    ent.Node(model, 1),
    ent.Node(model, 2),
    ent.Node(model, 3),
    ent.Node(model, 4),
component_collection = hm.Collection(model, ent.Component, "name=destination")
model.imprint_nodelist(
    list_source=node_list,
    collection_target=component_collection,
    options="remain 1 to_dest_component 0 remesh_mode 2 remesh_layers 2 angle 30.000000",
