Model.ossmooth_geometry#
- Model.ossmooth_geometry(modelsel, fem_filename, filepath_grid, filepath_sh, load_op, outputcode, tetrameshingcode, units, autobead, autobeadthreshold, autobeadlayer, isosurface, surfacecode, densitythreshold, detectbridge, lowthreshold, distancecoefficient, optismoothboundary, lapiteration, lapfeatureangle, lapsmoothboundary, remesh, surfacereduction, reductionfeatureangle, createplotel)#
Extract the final design geometry from OptiStruct topology, topography and shape optimization results.
- Parameters:
modelsel (int) –
Model selection option.
0 - Specify model file path to read.
1 - Use current model in HyperMesh.
fem_filename (hwString) – The full name and path to the OptiStruct .fem results file generated from the optimization. Used only when
modelsel = 1.filepath_grid (hwString) – The full name and path to the OptiStruct .grid results file generated from the optimization.
filepath_sh (hwString) – The full name and path to the OptiStruct .sh results file generated from the optimization.
load_op (int) –
Execution/load option. Valid values are:
0 - Create .oss file only to be used in standalone version (do not execute ossmooth)
1 - Do not load geometry into HyperMesh.
2 - Load geometry into HyperMesh.
outputcode (int) –
Output file format. Valid values are:
1 - Natran
2 - IGES
3 - STL
4 - H3D
tetrameshingcode (int) –
Flag indicating whether to create tetramesh after creating isosurface.
0 - No
1 - Yes
units (int) –
Units to use for IGES output. Valid values are:
1 - inch
2 - mm
4 - foot
6 - meter
10 - cm
autobead (int) –
Flag indicating whether to create an autobead design.
0 - No
1 - Yes
autobeadthreshold (double) – Threshold value for autobead (
autobeadthreshold≥ 0 and ≤ 1).autobeadlayer (int) – Layer value for autobead (
autobeadlayer=1 or 2).isosurface (int) –
Flag indicating whether to create an isosurface.
0 - No
1 - Yes
surfacecode (int) –
The method to use. Valid values are:
0 - No smoothing, isosurface only
1 - Optimization based smoothing
2 - No smoothing, element threshold
3 - Laplacian smoothing
densitythreshold (double) – The density threshold for topology optimization (
densitythreshold≥ 0 and ≤ 1).detectbridge (int) –
Flag indicating whether to detect connectivity in isosurface.
0 - No
1 - Yes
lowthreshold (double) – The lower density threshold for connectivity detection (
lowthreshold≥ 0 and ≤ 1). Low threshold must be smaller than density threshold value.distancecoefficient (double) – The distance coefficient to use in optimization based smoothing (
distancecoefficient≥ -50 and ≤ 50).optismoothboundary (int) –
Flag indicating whether to include the boundary or not in optimization based smoothing.
0 - No
1 - Yes
lapiteration (int) – The number of iterations to use in Laplacian smoothing (
lapiteration≥ 0).lapfeatureangle (double) – The feature angle to use in Laplacian smoothing (
lapfeatureangle≥ 1 and ≤ 80).lapsmoothboundary (int) –
Flag indicating whether to include the boundary or not in Laplacian smoothing.
0 - No
1 - Yes
remesh (int) –
Flag indicating whether to remesh when creating an autobead design or/and isosurface.
0 - No
1 - Yes
surfacereduction (int) –
Flag indicating whether to use surface reduction.
0 - No
1 - Yes
reductionfeatureangle (double) – The feature angle to use when requesting surface reduction (
reductionfeatureangle≥ 1 and ≤ 80).createplotel (int) –
Flag indicating whether to create PLOTEL elements.
0 - No
1 - Yes
Example#
Execute OSSmooth on the “ C:/test / os1.fem “ , “ C:/test / os1.grid “ and “ C:/test / os1.sh files “ , load geometry back to HyperMesh , request Nastran output , create 1 layer autobead with remesh design with 0.3 bead threshold , no surface reduction , 0.3 topology optimization threshold , detect connectivity in isosurface with 0.2 low threshold , Laplacian smoothing , 10 iterations , 30.0 degrees feature angle and include the boundary , create PLOTEL elements#import hm import hm.entities as ent model = hm.Model() model.ossmooth_geometry( modelsel=0, fem_filename="C:/test/os1.fem", filepath_grid="C:/test/os1.grid", filepath_sh="C:/test/os1.sh", load_op=2, outputcode=1, tetrameshingcode=0, units=1, autobead=1, autobeadthreshold=0.3, autobeadlayer=1, isosurface=1, surfacecode=3, densitythreshold=0.4, detectbridge=1, lowthreshold=0.2, distancecoefficient=0.0, optismoothboundary=0, lapiteration=10, lapfeatureangle=30.0, lapsmoothboundary=1, remesh=1, surfacereduction=0, reductionfeatureangle=10.0, createplotel=1, )
