Model.createfbdsummarytable#
Model.createfbdsummarytable(freebodysection_ids, subcase_ids, arrlen=25.0, arroworigin=0, colorfx=225, colorfy=65280, colorfz=16711680, colorfxy=0, colorfyz=0, colorfxz=0, colorfxyz=0, colormx=255, colormy=65280, colormz=16711680, colormxy=0, colormyz=0, colormxz=0, colormxyz=0, createfield=1, createload=1, declim=2, display=1, displacement=0, freenode=0, fx=255, fxy=0, fxyz=0, fxz=0, fy=65280, fyz=0, fz=16711680, mx=255, mxy=0, mxyz=0, mxz=0, my=65280, myz=0, mz=16711680, resfileid=1, resolvein_sys=0, resultid=Entity(), rotation=0, scid=1, scientific=0, showvalue=0, sizescale=0, stepid=0, tolerance=0.00001, user_sys_id=Entity(), vecstyle=0, gpf=0, intf=0, mpcf=0, sumat=0, sysproj=0, spcf=0, appf=0, absolute=0, color=255, createtable=0, displayat=0, envelope=0, field_name='', interpolate=0, maxval=0.000000, midarrow=0, minmax=0, normalload=0, onelems=0, onnodes=0, plotdir=0, range=1, report_tablename='', resultant=0, summf=0, tangentialLoad=0)#
Creates an FBD summary table or min/max table. This queries the GPF, Applied, SPC and MPC data from the result entity on a freebodysection.
Parameters:
  • freebodysection_ids (EntityList) – The list of freebodysection entities.
  • subcase_ids (hwTripleIList) – The subcase info as an array. Values are specified as [<resultfile_id>,<subcase_id>,<step_id>], with each list separated by a comma. For example: [[1,1,0],[1,2,0],[2,1,0],[2,1,1]].
  • arrlen (double) – The length of the string array that contains the additional input parameters.
  • freenode (int) –
    0 - Free nodes. Find the nodes which are shared by elements other than the elements contained in the freebodysection.
    1 - Boundary nodes. Find only the boundary nodes of the elements contained in the freebodysection.
    2 - All nodes. Find all nodes of the elements contained in the freebodysection.
  • resultid (Entity) – The object describing the result entity.
  • tolerance (double) – The tolerance to limit the values for table creation. Default is 0.00001.
  • user_sys_id (Entity) – The object describing the system entity.
  • intf (int) –
    0 - Internal forces are not participating in the FBD calculation (default)
    1 - Internal forces are participating in the FBD calculation
  • mpcf (int) –
    0 - MPC forces are not participating in the FBD calculation (default)
    1 - MPC forces are participating in the FBD calculation
  • spcf (int) –
    0 - SPC forces are not participating in the FBD calculation (default)
    1 - SPC forces are participating in the FBD calculation
  • appf (int) –
    0 - Applied forces are not participating in the FBD calculation (default)
    1 - Applied forces are participating in the FBD calculation
  • gpf (int) –
    0 - Grid-point forces are not participating in the FBD calculation (default)
    1 - Grid-point forces are participating in the FBD calculation
  • minmax (int) –
    0 - Create FBD summary table (default)
    1 - Create FBD min/max table
  • scientific (int) –
    0 - Fixed format text (default)
    1 - Scientific format text
  • scid (int) – The results subcase ID for result entity specified by resultid.
  • showvalue (int) –
    0 - Show text (default).
    1 - Hide text.
  • sizescale (int) –
    0 - Constant FBD plot arrow length (default)
    1 - Magnitude FBD plot arrow length
  • stepid (int) – The step/simulation ID for results subcase specified by scid.
  • resfileid (int) – The result file ID for resultid. Useful when multiple result files are loaded for a single result entity.
  • arroworigin (int) –
    0 - Tail of arrow at node for the plot (default)
    1 - Tip of arrow at node for the plot
  • fx (int) –
    0 - Fx translations are not included in the plot, load or field creation (default)
    1 - Fx translations are included in the plot, load or field creation
  • fxy (int) –
    0 - Fxy resultant translations are not included in the plot (default)
    1 - Fxy resultant translations are included in the plot
  • fxyz (int) –
    0 - Fxyz resultant translations are not included in the plot (default)
    1 - Fxyz resultant translations are included in the plot
  • fxz (int) –
    0 - Fxz resultant translations are not included in the plot (default)
    1 - Fxz resultant translations are included in the plot
  • fy (int) –
    0 - Fy translations are not included in the plot, load or field creation (default)
    1 - Fy translations are included in the plot, load or field creation
  • fyz (int) –
    0 - Fyz resultant translations are not included in the plot (default)
    1 - Fyz resultant translations are included in the plot
  • fz (int) –
    0 - Fz translations are not included in the plot, load or field creation (default)
    1 - Fz translations are included in the plot, load or field creation
  • mx (int) –
    0 - Mx rotations are not included in the plot, load or field creation (default)
    1 - Mx rotations are included in the plot, load or field creation
  • mxy (int) –
    0 - Mxy resultant rotations are not included in the plot (default)
    1 - Mxy resultant rotations are included in the plot
  • mxyz (int) –
    0 - Mxyz resultant rotations are not included in the plot (default)
    1 - Mxyz resultant rotations are included in the plot
  • mxz (int) –
    0 - Mxz resultant rotations are not included in the plot (default)
    1 - Mxz resultant rotations are included in the plot
  • my (int) –
    0 - My rotations are not included in the plot, load or field creation (default)
    1 - My rotations are included in the plot, load or field creation
  • myz (int) –
    0 - Myz resultant rotations are not included in the plot (default)
    1 - Myz resultant rotations are included in the plot
  • mz (int) –
    0 - Mz rotations are not included in the plot, load or field creation (default)
    1 - Mz rotations are included in the plot, load or field creation
  • colorfx (unsigned int) – The color of the Fx arrow. Valid values are 1-64.
  • colorfy (unsigned int) – The color of the Fy arrow. Valid values are 1-64.
  • colorfz (unsigned int) – The color of the Fz arrow. Valid values are 1-64.
  • colorfxy (unsigned int) – The color of the Fxy arrow. Valid values are 1-64.
  • colorfyz (unsigned int) – The color of the Fyz arrow. Valid values are 1-64.
  • colorfxz (unsigned int) – The color of the Fxz arrow. Valid values are 1-64.
  • colorfxyz (unsigned int) – The color of the Fxyz arrow. Valid values are 1-64.
  • colormx (unsigned int) – The color of the Mx arrow. Valid values are 1-64.
  • colormy (unsigned int) – The color of the My arrow. Valid values are 1-64.
  • colormz (unsigned int) – The color of the Mz arrow. Valid values are 1-64.
  • colormxy (unsigned int) – The color of the Mxy arrow. Valid values are 1-64.
  • colormyz (unsigned int) – The color of the Myz arrow. Valid values are 1-64.
  • colormxz (unsigned int) – The color of the Mxz arrow. Valid values are 1-64.
  • colormxyz (unsigned int) – The color of the Mxyz arrow. Valid values are 1-64.
  • createfield (int) –
    0 - Do not create a nodal displacement field (default)
    1 - Create a nodal displacement field
  • createload (int) –
    0 - Do not create FBD displacement loads (default)
    1 - Create FBD displacement loads
  • declim (int) – Controls the decimal limit. Default is 2.
  • display (int) –
    0 - Do not plot FBD displacements
    1 - Plot FBD displacements (default)
  • displacement (int) –
  • resultant (int) –
    0 - Free body force/moment plot.
    1 - Resultant force/moment plot.
  • sumat (int) – Reserved for future development.
  • sysproj (int) – Reserved for future development.
  • vecstyle (int) – Reserved for future development.
  • rotation (int) – Reserved for future development.
  • resolvein_sys (int) – Reserved for future development.
  • absolute (int) – Reserved for future development.
  • color (int) – Reserved for future development.
  • createtable (int) – Reserved for future development.
  • displayat (int) – Reserved for future development.
  • envelope (int) – Reserved for future development.
  • field_name (hwString) – Reserved for future development.
  • interpolate (int) – Reserved for future development.
  • maxval (double) – Reserved for future development.
  • midarrow (int) – Reserved for future development.
  • normalload (int) – Reserved for future development.
  • onelems (int) – Reserved for future development.
  • onnodes (int) – Reserved for future development.
  • plotdir (int) – Reserved for future development.
  • range (int) – Reserved for future development.
  • report_tablename (hwString) – Reserved for future development.
  • summf (int) – Reserved for future development.
  • tangentialLoad (int) – Reserved for future development.
Examples#
Create an FBD summary table#
import hm
import hm.entities as ent
model = hm.Model()
model.createfbdsummarytable(
    freebodysection_ids=[
        ent.Freebodysection(model, 1),
        ent.Freebodysection(model, 2),
        ent.Freebodysection(model, 3),
    subcase_ids=[[1, 1, 0], [1, 2, 0], [2, 1, 0], [2, 1, 1]],
    arrlen=9,
    tolerance=0.00001,
    resultid=ent.Result(model,1),
    gpf=1,
    appf=1,
    spcf=1,
    intf=1,
    mpcf=1,
    freenode=0,
    minmax=0,
Create an FBD min/max table#
import hm
model = hm.Model()
    arrlen=9,
    tolerance=0.00001,
    gpf=1,
    appf=1,
    spcf=1,
    intf=1,
    mpcf=1,
    freenode=0,
    minmax=1,
