Model.CE_DetailDelete#
Model.CE_DetailDelete(ce_id, detailType, detailName, unknownFlag)#
Deletes connector details (stored in connector metadata) from connectors specified by ID.
Parameters:
  • ce_id (unsigned int) – The ID of the connector to delete details from.
  • detailType (hwString) – Detail type to delete. Valid values are “int”, “uint”, “double”, “string” and “triple”.
  • detailName (hwString) – The name of the detail to delete.
  • unknownFlag (unsigned int) – Reserved for future development. Must be set to 0.
Example#
Delete user-defined integer details named “test” for connector with ID 2#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_DetailDelete(ce_id=2, detailType="int", detailName="test", unknownFlag=0)
