Model.ME_ModuleOccurrenceCreate#
- Model.ME_ModuleOccurrenceCreate(name, parent_part_entity=Entity(), structural_type='', udm_id='')#
Creates a module part.
- Parameters:
name (hwString) – The name of the part module to create.
parent_part_entity (Entity) – The object describing the part entity you wish to make this module a child of. If not specified, the new module is placed underneath the root model module.
structural_type (hwString) –
part
A part is the default if not specified, and can coverts to a part assembly. A part assembly cannot be converted to a part.
udm_id (hwString) – The string ID from a UDM XML file for this part, if necessary.
Example#
Create a new Part module named “mypartname” as a child of the module with ID 2#import hm import hm.entities as ent model = hm.Model() model.ME_ModuleOccurrenceCreate( name="mypartname", parent_part_entity=ent.Part(model, 2), structural_type="part" )
