Model.morphnodesnodesoffset#
Model.morphnodesnodesoffset(e_collection, f_collection, t_node_list, m_node_list, nproj, c_vec, integ, mbias, fbias, envelope, undisplayed, offset)#
Moves the selected nodes to a line created using a node list. The moving nodes may be projected to the line along a vector, normal to the line, or fit to the line (even distribution). The fixed nodes are held in place and the affected elements (or all unfixed nodes in the model if integ is 3 or 6) are stretched according to the value of integ.
Temporary handles are created for all moving and fixed nodes to determine the stretching of the affected elements. If integ=0, a general domain is temporarily created for the affected elements. If integ=1, the domains currently in the model are used. If integ=2, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements but the 2D domains are not partitioned. If integ=3, then handle influences are applied using a spatial relationship rather than through a domain. If integ=4, only the selected moving nodes are moved and all others are held fixed. If integ=5 , 1D, 2D, 3D, and edge domains are temporarily created for the affected elements and the 2D domains are partitioned. Any handles created due to partitioning are moved based on their distance from the moving and fixed nodes. If integ=6, then handle influences are applied using the Kriging algorithm. If integ=7, then handle influences extend only up to a given distance (if envelope is positive) or a given multiple of the applied perturbations (if envelope is negative) away from the moving nodes.
The bias factors function as they would for handles except that all moving nodes will have the mbias value and all fixed nodes will have the fbias value.
If no elements are selected and nproj=2, all elements in model are used to determine projection vectors.
If integ is set to 3, 6, or 7, nodes on undisplayed elements and components can be morphed, fixed, or excluded depending on the value of undisplayed.
If offset is non-zero, the moving nodes will be offset from the mesh by the specified amount.
Parameters:
  • e_collection (Collection) – The collection containing the affected element entities.
  • f_collection (Collection) – The collection containing the fixed node entities.
  • t_node_list (EntityList) – The list of node entities for the line to which the nodes will be moved.
  • m_node_list (EntityList) – The list of the moving node entities.
  • nproj (int) –
    0 or 10 - Project along vector given by c_vec
    1 or 11 - Project normal to lines
    2 - Fit nodes to line
    If offset is non-zero, the offset will be measured from the closest point on the lines for values of 0 and 1. The offset will be measured along the projection vector or normal for values of 10 and 11. Offsets will not be applied for a value of 2.
  • c_vec (hwTriple) – The hwTriple object defining profile plane normal components for the projection direction (nproj=0). User can also supply a Python list of three doubles.
  • integ (int) –
    0 - Free edges (a single general domain)
    1 - Use existing domains
    2 - Inferred edges (1D, 2D, 3D, and edge domains - no partitioning)
    3 - Morph all nodes using a proximity algorithm
    4 - Morph all moving nodes and fix the unselected nodes
    5 - Partitioned edges (1D, 2D, 3D, and edge domains with partitioning)
    6 - Morph all nodes using the Kriging algorithm
    7 - Morph all nodes within an envelope around the moving nodes
  • mbias (double) – Bias factor of moving nodes.
  • fbias (double) – Bias factor of fixed nodes.
  • envelope (double) –
    If positive, all nodes beyond the given distance away from the moving nodes will be fixed.
    If negative, all nodes beyond a distance calculated by multiplying the total perturbation of each moving node by the absolute value of the envelope and extended away from each moving node will be fixed.
    If integ=7, the calculated distance defines an envelope around the moving nodes within which the morphing of those nodes will linearly taper from fully matching the nearest moving node to zero at the edge of the envelope. If any fixed nodes are within the envelope they will also reduce the morphing of nearby nodes.
  • undisplayed (int) –
    If integ is set to 3, 6, or 7, nodes which are not displayed can be affected by the morphing. This defines how undisplayed nodes are handled:
    0 - Morph nodes on undisplayed elements
    1 - Fix nodes on undisplayed elements, they will function just like nodes on the fixed collection
    2 - Exclude nodes on undisplayed elements, they will not be morphed nor affect the morphing
  • offset (double) – The distance to offset nodes from the target. The offset will be measured from the closest point on the lines for values of nproj of 0 and 1. The offset will be measured along the projection vector normal for values of nproj of 10 and 11.
Example#
Move a collection of nodes to be offset 1.2 from a node list normal to the node list and stretch all the elements in the model use the exist domains#
import hm
import hm.entities as ent
model = hm.Model()
model.morphnodesnodesoffset(
    e_collection=hm.Collection(model, ent.Element),
    f_collection=hm.Collection(model, ent.Node, [21, 22, 23]),
    t_node_list=[ent.Node(model, 51), ent.Node(model, 52), ent.Node(model, 53)],
    m_node_list=[ent.Node(model, 61), ent.Node(model, 62), ent.Node(model, 63)],
    nproj=0,
    c_vec=[1.0, 0.0, 0.0],
    integ=1,
    mbias=1.0,
    fbias=1.0,
    envelope=0.0,
    undisplayed=0,
    offset=1.2,
