Model.morphmapnormaloffset#
Model.morphmapnormaloffset(collectionelem, collectionfix, sym, con, blend, offset, umark)#
Offsets elements on collection in normal direction.
Parameters:
  • collectionelem (Collection) – The collection containing the element entities to map.
  • collectionfix (Collection) – The collection containing the fixed node entities.
  • sym (int) – 0 - Do not use symmetry (only option).
  • con (int) –
    0 - Do not use constraints
    1 - Use constraints
  • blend (int) –
    0 - Do no blend unselected nodes
    1 - Blend nodes between mapped and fixed nodes
  • offset (double) – Distance to offset elements
  • umark (int) –
    0 - Use all elements to calculate normals
    1 - Use selected elements to calculate normals
    2 - Use CFD corners
    Adding 10 to any value use only elements on mark for normal calculation. Otherwise, all elements are used.
Example#
If blend is on, no fixed nodes have been selected, and no mapped nodes are a part of any domain, this function will automatically assign all non-mapped nodes as fixed nodes#
import hm
import hm.entities as ent
model = hm.Model()
model.morphmapnormaloffset(
    collectionelem=hm.CollectionByInteractiveSelection(model, ent.Element),
    collectionfix=hm.CollectionByInteractiveSelection(model, ent.Node),
    sym=0,
    con=1,
    blend=0,
    offset=10.0,
    umark=1,
